Clutch assembly and live hydralics for 47 R
steve
05-11-2003 16:18:26
my father is rebuilding my grand fathers 47 R and is about ready to start putting together again but has realized that he is unsure as to the correct assembly of the clutch. anyone got step by step so he won't have to rely solely on intuition? Also, he has read that the R came with optional live hydralics and is interested in whether or not this is true and if so what is chance of installing on this one. Thanks alot to any and all info on these two subjects.
BMG
05-11-2003 16:34:43
 Re: clutch assembly and live hydralics for 47 R in reply to steve, 05-11-2003 16:18:26
Steve,
The R model came with "live" hydraulics. This system consisted of a pump mounted to the left side of the engine that was driven by the camshaft. If your 47 R has a square cover on the left crankcase cover this is where the small live hydraulic pump would have mounted. This system used engine oil from the motor instead of a seperate reservoir & hydraulic fluid. It was mainly designed to lift cultivators or a sickle mower. It was not very fast.
Brian
craig h
05-11-2003 18:55:22
 Re: Re: clutch assembly and live hydralics for 47 R in reply to BMG, 05-11-2003 16:34:43
Later model R&Z's also could come with factory hydraulics drivin from timing gear mounted on side cover at oil filler/breaher housing had a remote hyd. tank mounted under fuel tank in front of battery
freddy
05-12-2003 15:18:08
 Re: Re: Re: clutch assembly and live hydralics for 47 R in reply to craig h, 05-11-2003 18:55:22
Late model r's even came with 3 point lift.
