Governor Problem
ANdy
05-11-2003 19:48:09
I am working on a RTU and the governor alway sticks and i have worked with it all day. If you can help or tell me where i can get one tell me please.
Andy
05-12-2003 12:23:05
 Re: Governor Problem in reply to ANdy , 05-11-2003 19:48:09
Make sure your linkage is totally free. When you have it on idle you should be able to lift up the the linkage up and it should fall down on it's own. You may have to bend or tweek it a bit. Motec rebuilds them.
Kelvin
05-12-2003 18:42:34
 Re: Re: Governor Problem in reply to Andy, 05-12-2003 12:23:05
some thoughts: Have you witnessed it working O.K. in the past?
If you worked on the carb, does the throttle shaft turn absolutely free with the governor rod off.
Another thought: have you tried loosening the carb and shifting it to one side or the other, to remove any bind in the linkage.
One thing I've tried on a U, but never on Z or R:
disconnect the throttle link from the governor, start the tractor, holding carbruretor throttle closed (idle), set tractor throttle at idle and see where the governor arm wants to be in relation to the link.
Kelvin
05-12-2003 18:42:16
