MM
GB question
MM
05-14-2003 13:20:00
How much does a MM GB diesel weigh and what is the horsepower rating for it? Also, about how much should one sell for that's been restored? I'm thinking about buying one for pulling?
Thanks.
ACEd
05-18-2003 18:53:13
 Re: MM - GB question in reply to MM, 05-14-2003 13:20:00
Factory specs MM GB Diesel 64 belt HP, 56 drawbar HP. 425.5 ci. Governed speed 1300 rpm.
Factory Total Weight on 15-34 tires without weights or ballast was 7400 pounds. Similar weight for GB gas/LP was 6600 pounds and LP was rated 74 belt HP/ drawbar HP which was advertised in 1955 as highest HP tractor available. Note these were the smallest tires - more common was 16-34 or 18-26 on gas/lp.
Factory weight options 400 or 650 pounds each weight and common was to use double 400 each rear. Front weights 55 pounds each - I think that was per weight inboard & outboard. Plus there was a chin weight. Ballast added nearly another 1000 pounds per rear - not uncommon to see top of 11,000 pounds maxed out.
As to value - I don't have a clue.
MM
05-19-2003 10:57:10
 Re: Re: MM - GB question in reply to ACEd, 05-18-2003 18:53:13
Thanks for the info ACEd. That really is a powerful tractor. I'm still looking for one.
