A4T1400 Motor Problems
eb
05-17-2003 05:52:33
Have an A4T1400 that originally the turbo leaked oil. Had the injectors done. Motor runs rough when cold like it is missing. The motor was rebuilt recently. Could the pump be bad or not timed properly?
Captainhookerus
05-17-2003 17:45:16
 Re: A4T1400 Motor Problems in reply to eb, 05-17-2003 05:52:33
Since you just had the nozzles out, does it run worse than before? I would guess it does. Throw those self locking nuts that hold the nozzles away. Use some new nuts without lockwashers and tighten them evenly to 144 to 180 inch lbs. This will keep the nozzle housing from distorting causing the pintle to stick.
Ken
