Mimmie Mo or Avery
1944_A-aron
05-22-2003 12:09:52
My grandpa has a tractor that he is wanting me to restore. The problem is that none of us are sure what brand it is. We call it an Avery because on the back in the cast it has B F AVERY. I also know that minne moline Made a model BF for 2 or 3 years (LOOKING SIMILAR) it has red and yellow paint when you scratch through it. If anyone knows any info or what th year is, Thanks in advance. Aaron I have pics if I can figure out how to post.
Tyler Janke
05-23-2003 08:07:32
 Re: Mimmie Mo or Avery in reply to 1944_A-aron, 05-22-2003 12:09:52
I think its a model V. BF avery produced these before MM bought them out but MM continued to produce them under the MM name and continued to call them the V. The only way to tell is the check the serial numbers which would be stamped directly into one of the frame rails.
Larry from MD
05-23-2003 13:17:37
 Re: Re: Mimmie Mo or Avery in reply to Tyler Janke, 05-23-2003 08:07:32
Its a V allright the moline version is supposed to have a differant front end than the avery,acording to the service manuel.Its real hard to see in the picture ,but it looks like the moline version.
Warren from Michigan
05-23-2003 02:49:35
Does this tractor have a narrow or wide front end?
If it is narrow does it have one front wheel or two?
Does it have 28 inch rear wheels or 24 inch wheels?
MM bought out BF Avery in early '50, so if it is an Avery it would be an early '50
swnewton@glis.net
1944_A-aron
05-23-2003 07:53:08
 Re: Re: Mimmie Mo or Avery in reply to Warren from Michigan, 05-23-2003 02:49:35
wide front end and i think 24 inch wheels i'll have to check for sure i will post a pic here if i can there is also a pic in the help identify gallery
05-24-2003 03:40:54
 Re: Re: Re: Mimmie Mo or Avery in reply to 1944_A-aron, 05-23-2003 07:53:08
More info on minnie mo or Avery. The ser # is stamped on top of the right frame rail by the bell housing. 1951 6v207-6v421 1952 6v422-7v271 1955 8v121 Hope this helps
Larry from MD
05-22-2003 17:17:04
Look for the serial number on the frame near the clutch on the right hand side.Then look up the year on the left of the page or post back here.
