M-670 oil filter and tele-flo
G. L. Perry
05-24-2003 21:36:59
670 has an oil filter cartridge and I have it out. Parts book shows the canister loose from pan. I can't seem to get it out, have the screws out, just won't budge. I wanted to change seal ring and gonna see if I can clean out pan of sludge and junk. I can see the pipes from oil pump in back. Doesn't this just slip out? Even the filter took quite a pull to get out. Didn't want to mess up, so quit for now.
My teleflo leaked while I was trying flushing it. I broke off a lead in pipe on front of "stack" valve unit. Can I get the pce in it out with EZ-out? I have the whole unit loose and ready to come off tractor to work on. I don't really want to go inside if I don't have too. I can't figure out what this pipe goes to, it passes thru the cover with big hole there. This is the one that has the pressure side lead-in on it. Also, can you still get those step hoses and connector hoses? One is two sizes in one. Other is 1-1/4" hose, I can only find 1". Needs to be return type hose, not the hydro hose with steel wire in it.
