51 B.F. avery 'R' wont start
Corvairkid
05-25-2003 20:33:46
Hi,
My new 'R' won't start. I just bought it and it did not run when I got it. I had to replace the wire harness which I did. The PO told me it was a 6 volt system. How can I be sure it is? The PO did not own it very long and only started it once.
The part number on the starter is 1109475 and the generator part number is 1101836.
I replaced the plugs and wires, inspected the points which look new, and tried to pull start the thing. It fired a few times but would not run on its own.
Any ideas?
Thanks,
Corvairkid
BMG
05-26-2003 10:57:54
 Re: 51 B.F. avery 'R' wont start in reply to Corvairkid, 05-25-2003 20:33:46
Are you sure your generator is not 1101856 instead of 836? The 856 is listed as original equipment 6 volt. I can't identify the starter # you listed. All BF Averys were 6 volt system from the factory.
Brian
Glen Emery
05-25-2003 21:53:23
I would check the mag or distributor, then the fuel supply. Is the carb getting gas? Is the carb clean and working? Are you getting spark at the end of the plug wires?
