LS 300 Spreader
Steve Thompson
06-06-2003 00:31:49
I'm trying to restore a LS 300 spreader. And don't know what kind of wood I should use? Will be used for show and kepted inside. Thanks Steve
Roger
06-08-2003 20:38:41
 Re: LS 300 Spreader in reply to Steve Thompson, 06-06-2003 00:31:49
I have resored 3 of these spreaders. They are
great to put literature in at a show. You will
need to measure the spreader at the front and the
back. The ones I have are 1 1/2 inch wider at the
back. Guessing this was to keep the manure from
packing and wedging as it went back.
John G
06-09-2003 06:31:55
 Re: Re: LS 300 Spreader in reply to Roger, 06-08-2003 20:38:41
Roger, What kind of wood did you use? How /or do you make it water proof for the literature? I've got one that needs wood also. Would like to use it for displays. Thanks, John
Roger
06-09-2003 09:23:59
 Re: Re: Re: LS 300 Spreader in reply to John G, 06-09-2003 06:31:55
The original wood was Pine on all 3 that I restored.
I am fortunate to have a good source of lumber. I
used clear Pine, cheaper and lighter. I did paint
them back to original color. I do keep them
inside. You can put liturature wrapped in plastic
under the slats. It keeps the wind from blowing it
away. Good place to lean an MM sign also.
Steve Thompson
06-10-2003 10:59:07
 Re: Re: Re: Re: LS 300 Spreader in reply to Roger, 06-09-2003 09:23:59
My spreader was pine also. I am going to use white pine but boy does it have knots in it.Thanks for the reply.Steve
John G
06-09-2003 13:45:01
Thanks Roger, John
Kevin Moschenrose
06-07-2003 07:09:10
If I am not mistaken mine has oak on it. I would use a hard wood to restore it. But pine would be o.k. for showing too,like Kelvin said a clear pine is best with no knots in it. Knots will loosen up and fall out.
kelvin
06-06-2003 17:17:41
I don't know what is available in your area. If I were doing it here in NC, I would like to use treated pine, preferably yellow pine. (its stronger)
Go to your lumber yard with a list of the sizes you need, pick out the best boards available with little warp, no bow or twist and few small knots (prefer no knots at all). If the spreader used extremely wide boards-over 7-1/2" you might have to compromise and use some narrower boards. Its very hard (and expensive) to find good lumber any larger than that around here.
