Blowing the dust off my zb
old fart
06-11-2003 02:04:53
Have a couple questions, first does the zb have potential to be a competitive puller? And what weight would it be in a stock situation. The old girl was put in the shed tired when the livestock were sold twenty years ago. I reckon it will be a handful to get her back in shape again. The kids are gone so its time to give it a try. Thanks
Andy
06-11-2003 06:58:51
 Re: blowing the dust off my zb in reply to old fart, 06-11-2003 02:04:53
They are good stock pullers. If you take the cultivator lift off they will make 4,000 lbs (depending on driver size). They lug very well. They do come up short on power above 5000 lb on a hard track.
CHAD
06-13-2003 08:25:42
 Re: Re: blowing the dust off my zb in reply to Andy, 06-11-2003 06:58:51
HI THERE! I HAVE A MM ZAU THAT I RECENTLY PULLED AND I PLACED SECOND IN THE STOCK CLASS! I REBUILT THE CARB AND DISTRIBUTOR AND GOT 40 HP. GOOD LUCK
John G
06-13-2003 04:57:25
We have a '37 JTU with a 206 bored to 3 3/4", has cast wheels, 2 sets rear weights, 2 100# weights out front, power lift, it's competitive in the '39 & older 5500# class. Yours should do well in a 4000 or 4500# class. I think you will have to remove the whole power unit from the rearend to get down to that weight. Good luck!!
Mike A
09-11-2003 15:20:10
 Re: Re: Re: blowing the dust off my zb in reply to John G, 06-13-2003 04:57:25
John G..... I have a '37 JTU, s/n 555032, and it needs a lot of work! It's loose and rolls freely, but there's a lot of rust. I put new rubber on and now need directions! Do you have any manuals or guides that I can start with? She looks good sitting here, but I want to get her up and going. Thanks for your time.
old fart
06-14-2003 12:47:26
Thanks boys for the info, crops are looking good if only the rains would settle down. Have a good weekend and happy "Fathers Day" to all .Take care from northern Minnesota//old fart10/4
old fart
06-12-2003 21:15:12
thanks andy, will give it a pull out and see what we have to start with. is the arms alone weight enough to remove or does the shaft have to come out to .
