Filter for Hydraulics, 670
G. L. Perry
06-14-2003 02:09:17
I find filters for my hydraulics that are the correct for my 670, they all seem too long by about 3/8" or so. Can you fellas that use these tell me if they will really "crush" that much or hard when pulling together with the single bolt on top of housing? I can't see it doing it, but am going crazy trying to get back together. The center of upper housing casting is lower than the outer edge and would be better if it was same depth or if filter had a dip in one end, which it doesn't have. I can't see anything "extra" in housing cover? Can someone measure their housing inside and see what it is? I'll compare to mine. any pictures of upper part that lines run into available to see inner part?
