MM metal labels/names glued?
G. L. Perry
06-17-2003 01:34:40
I have a JS3 and jus got an M670. Both about 66 or 67. My Jet Star had the MM and name labels on hood and grills glued on, no fasteners used, but holes in the badges. I thought someone just did that in haste or laziness. NOW, I see the 670 has the same deal, glued on. The glue is fairly stiff, much like Vynil Cove moulding cement for homes. What was this stuff? I'm thinking of using stainless screws or ? to refasten. What have you fellas used or did you glue and what was used?
Larry O.
06-17-2003 19:27:18
 Re: MM metal labels/names glued? in reply to G. L. Perry, 06-17-2003 01:34:40
On our G 1000 Vista they are Pop rivited on and that is the way it came from the factory. Thet used the white painted pop rivets. Maybe you could do that too. Larry O.
Kelvin
06-17-2003 18:45:46
having driven a Super 55 oliver with loose gas door, can tell you glue was used to eliminate at least that one cause of an annoying rattle. To make sure you don't loose those costly things, I'd back up the glue with the SS screws.
