Distributor Springs for Recurve on U
molinedistr
06-17-2003 21:25:42
Does anyone know where to get distributor advance springs for recurved Delco distributors? I have a U and need to find some without paying for the recurve all over again.
Kelvin
06-18-2003 19:22:58
 Re: Distributor Springs for Recurve on U in reply to molinedistr, 06-17-2003 21:25:42
Unless you know what spring was installed the first time you're probably out of luck.
Changing the springs and changing the number of degrees it advances by cutting or lightening the weights, or modifying their travel on the shaft,is about all you can do to change the advance curve.
Automobile 'advance recurve kits' used to just include an assortment of springs. (along with some way to change the vacum advance, which your U distribuitor does not have).
Trever Maas
06-18-2003 20:20:23
 Re: Re: Distributor Springs for Recurve on U in reply to Kelvin, 06-18-2003 19:22:58
Kelvin is right.
There isn't a lot you can do. Have you modified the engine at all or why do you want to change the ignition curve?
If you need some springs and if automobile springs would work I would give you some leftover ones from a recurve kit. Not sure if they would work but I thought I would help if at all possible.
