Head gasket sealer????????
Family Traditio
06-23-2003 07:19:28
what kind of head gasket sealer should i use on a U Moline w/ 300 lbs. of compression?....can not keep head gaskets on my puller
No surprise
06-23-2003 13:06:06
 Re: head gasket sealer???????? in reply to Family Tradition, 06-23-2003 07:19:28
Wonder what is the matter. 300/14.7 = 20.4 Compression ratio Looks like you should be wondering what cylinder heads to change to instead of head gasket sealant.
Jerry
06-23-2003 17:42:00
 Re: Re: head gasket sealer???????? in reply to No surprise, 06-23-2003 13:06:06
I believe that you probably need the rings cut into the heads and blocks but you probably don,t have the room. Sounds like you probably should get your compression down before you push your rods thru the tops of the pistons.
deadeye
06-24-2003 02:31:17
 Re: Re: Re: head gasket sealer???????? in reply to Jerry, 06-23-2003 17:42:00
With 300 lbs of compression, you are not going to hold the mains in very long on a 4 cylinder. Seems to have a tendency to pound them right out with the explosions gong on inside of each cylinder. Something has to give and the weak point will give first.---deadeye
Family Tradition
06-24-2003 07:48:19
 Re: Re: Re: Re: head gasket sealer???????? in reply to deadeye, 06-24-2003 02:31:17
this motor has been holding together for 2 years other than replacing head gaskets turning 2300 rpms
