CHRIS in SO. IN. --I need to talk to you.
Doug
06-23-2003 16:33:11
I am restoring a ZB. I also live in So. Ind.
I need some help with some parts-etc.
Thanks (of course anybody else's help is nice too!)
Joe Leising
06-23-2003 17:08:36
 Re: CHRIS in SO. IN. --I need to talk to you. in reply to Doug, 06-23-2003 16:33:11
I live in Indiana as well. I have a ZB. What do you need?
Joe
Doug
06-24-2003 07:40:15
 Re: Re: CHRIS in SO. IN. --I need to talk to you. in reply to Joe Leising, 06-23-2003 17:08:36
Well I don't havt it apart yet, but I know I need a 38" wheel, and some steering gear parts. That's just for starters. I saved this old iron from the baler, so it's not very cherry.
I'm an antique car restorer professionally, And i have a need for a tractor, and I always liked Molines, (Grandpa always farmed with them). This one was given to me instead of going to the scrap. It has a 3pt. lift, and a live PTO, So for some mowing, It will be great when I'm done with it.
Alan K
06-25-2003 20:49:12
 Re: Re: Re: CHRIS in SO. IN. --I need to talk to y in reply to Doug, 06-24-2003 07:40:15
The ZA's used the same rim as the ZB's, you probably knew that allready. Another place you can possibly find one would be on some "A" JD's. They used the same rim on some of them. My dad bought a ZA new in 1950 and it has both the MM # and a JD #. The JD # can be found about 1 foot to the left of the valve stem, (1259D I think). The MM # is on the inside part of the rim by the bead. Hope this helps.
Alan
Joe Leising
06-24-2003 17:54:19
How bad is the rim you have? I have a couple of patch rims if you need a piece. I also know where some steering gear parts may be if you need them.
Joe
