MM LP help.
Bill
06-27-2003 14:40:42
howdy, got a 61 gvi lp. it's got a sticky valve, are there any precautions I need to heed before trying to fix it. I didnt know if there is anything special I need to consider for this repair. thanks in advance.
Howard H.
07-02-2003 14:55:10
 Re: MM LP help. in reply to Bill , 06-27-2003 14:40:42
Hi Bill,
I haven't worked on a MM tractor engine before, but I've run quite a few MM stationary engines for irrigation motors.
One time, I had an HD 800 with a sticky valve and I just trickled a quart of motor oil into the air intake while it was running. It smokes and spits, but sure oils up the top side of the engine.
You might try that and see if it helps. It fixed my irrigation motor.
Howard H.
