G-706 parts
Bruce Buchert
02-21-1999 15:51:43
I am looking at a G-706 LP to purchase. Owner says clutch is weak and I am trying to check on replacement availability. I would appreciate any info on clutches.
mm
02-21-1999 20:33:34
 Re: G-706 parts in reply to Bruce Buchert, 02-21-1999 15:51:43
The clutches on the 706 is adjustable. There is a small pin that pulls out of a collar inside the bellhousing. The pin is spring loaded. You need to pull out the pin and turn it a notch or two and the clutch will have a more destinct snap. Only if the adjustment is completely taken up will the clutch need to be replaced. Chances are this is an easy on.
Jerry
02-22-1999 08:29:51
 Re: Re: G-706 parts in reply to mm, 02-21-1999 20:33:34
Sometimes the adjustment is very hard to turn. It it has not been adjusted for a while.
