Heads for 1954 MM model ZB
GaryW
06-28-2003 14:54:56
Can anyone tell me where I can get cylinder heads for a 54 ZB? The tractor belongs to a friend of mine. He tells me that there are two heads on this model.
Justin
08-03-2003 13:48:34
 Re: Heads for 1954 MM model ZB in reply to GaryW, 06-28-2003 14:54:56
I am working on a 51 uts I was told that the internal parts from a gb lp will bolt wright in. Is this true? I would also like any heplful hints into bulding a puller with my UTS.
Glenn
06-28-2003 15:08:05
Your friend is wrong. The ZB has only 1 head, as does the Z series and the R . two cylinder jugs, but only one head.
GaryW
06-28-2003 15:20:35
 Re: Re: Heads for 1954 MM model ZB in reply to Glenn, 06-28-2003 15:08:05
Glenn,
I don't know much about MM. Can you recommend a source where he could get a head for this tractor?
GaryW
Glenn
06-28-2003 15:25:00
 Re: Re: Re: Heads for 1954 MM model ZB in reply to GaryW, 06-28-2003 15:20:35
Everret Bros. in Ohio/ 740-922-3335
GaryW
06-28-2003 15:27:32
 Re: Re: Re: Re: Heads for 1954 MM model ZB in reply to Glenn, 06-28-2003 15:25:00
Glenn,
Thanks, I'll give them a call.
GaryW
John G
06-28-2003 16:01:06
 Re: Re: Re: Re: Re: Heads for 1954 MM model ZB in reply to GaryW, 06-28-2003 15:27:32
Gary, What fuel are you going to be using? There is only 1 head on the tractor, but there are at least 7 to choose from. They varied the compression ratio by changing the head configureation. If you are on LP, expect to pay $300 to $450 for a head. If gasoline, much less, I have a couple of gasoline heads for $100 each OBO. I'm in extreme northeastern Illinois. Thanks, John
GaryW
06-28-2003 20:51:06
 Re: Re: Re: Re: Re: Re: Heads for 1954 MM model ZB in reply to John G, 06-28-2003 16:01:06
JohnG
A good friend of mine owns this tractor. I'm not sure if it's on propane or gas. I spoke with him today and he told me he had a cracked head and wanted to fix this old tractor up. He is thinking that it has two heads. Do you have a picture or diagram of the head and block you could e-mail me? I'll check with him to see if it is propane or gas and post back. If it is on gas I think he will be interested. Thanks for your help.
GaryW
John G
06-29-2003 06:26:14
 Re: Re: Re: Re: Re: Re: Re: Heads for 1954 MM mode in reply to GaryW, 06-28-2003 20:51:06
Gary, This engine has 2 seperate blocks, is a flathead with the valves horizontal above the cylinders. Has only one head on the right side of the engine. There will be a casting # on the head near the front of it. It will be RE226? or 10A???? If he can get that, we'll know for sure which head he has. John
bud barenie
06-28-2003 16:47:37
to john g
john how do i find all the info on moline (head and block) casting numbers and what they mean
bought my first molin (1953u.b.)
al info appreaciated
John G
06-28-2003 17:29:28
 Re: Re: Re: Re: Re: Re: Re: Heads for 1954 MM mode in reply to bud barenie, 06-28-2003 16:47:37
Bud, I have a list of some of the MM heads, I'll see if I can find a way to scan and send them. Need your email, did you buy it today at an auction in extreme NE Illinois? If so, I'm 5 miles from the auction. We will be at the Oak Creek Wisconsin show tomorrow. I have a '50 UTS LP there, maybe see you there. John
