Live PTO on UB
Trever Maas
07-03-2003 14:17:29
Does anyone have a picture of the live pto assembly for an early UB? When I bought the tractor I noticed that the lever was gone. At that time I didn't know that there was a sort of a bolt or stud that holds the lever on. Now that I know that, there must be something missing. I've got the assembly out of the tractor and put in order for easy installation. But I haven't a clue as to what i'm missing. I found some grease/oil in there that could also be on the brake linings which is bad. Also, can someone tell me the operation and/or principle of this? It seem's like a piss-poor patent to me. It could have it's advantages but I think something newer like an M670 or equivalent is a much better design. Any help would be great!
Thanks,
Trever
Mopower
07-04-2003 20:27:06
 Re: Live PTO on UB in reply to Trever Maas, 07-03-2003 14:17:29
I was recently in to a live power setup. We removed the lever and took the clutch springs out to eliminate slippage. The PTO cluch has been known to slip during heavy pulling. This was also done in the past on Grandpa's UBD. My 2 cents. I may have a picture somewhere, but it does not explain much. We just sold a 1952? UTU that has the live PTO too. It worked fine.
havvey
07-03-2003 18:25:58
on the ub it was a device like a clutch that tood the rear wheall out of gear the lever jut put it in and out allis wd and massey 44 had similar devices it did work good and the ub was awsome
Trever Maas
07-04-2003 09:02:47
 Re: Re: Live PTO on UB in reply to havvey, 07-03-2003 18:25:58
Thank you!
I was told that it was a bad patent because if your pulling something sometimes the discs would slip and leave you stranded. It's happened to my grandpa on his new UB Special out in the field while plowing. He had his discs welded up due to that happening.
I finally found a parts explosion of a live power take-off unit.
Thanks,
Trever
