MM ZB Valves
david
07-05-2003 18:32:39
HEllo guys i just bought an mm zb and it is stuck. I used a grease gun in the spark plug holes on a UTS i had to break it loose but i went to do that to this zb i found out that one of the keepers on the valve springs is missing i was wondering if anyone had 1 or 2 they would want to sell thanks!!!
joco
07-06-2003 12:17:36
 Re: MM ZB Valves in reply to david, 07-05-2003 18:32:39
also try auto parts stores they are fairly common
AZ Jack
07-05-2003 21:34:33
David-I think some Chevrolet valves will adapt to the engine. You might try the keepers for these to see if they will work. This is just a shot in the dark and may not work-but is worth a try.
Joe Leising
07-05-2003 21:06:20
Send me an e-mail with you address. I may have a couple I can just send you if your not in a big hurry.
Joe
david
07-06-2003 10:31:48
 Re: Re: MM ZB Valves in reply to Joe Leising, 07-05-2003 21:06:20
Thnks a bunch my address is
David Smith
R.R. Box 57 Stronghurst, IL 61480
i tried sending an email to you but it said your address is blocked so i was hoping you would read this. When i get the keepers from you i will send you a money order for them thank you very very much sir!!!
