M5 water pump shaft
Mark
07-08-2003 12:04:50
I'm putting new seals in my M5 water pump and there is a groove worn on the shaft. Can I just not drive the seal all the way on and still have it work? Or is that asking for another problem? Thanks for any ideas, Mark
John Mc
07-10-2003 09:39:44
 Re: M5 water pump shaft in reply to Mark, 07-08-2003 12:04:50
I never had a M5 water pump apart, so I don't know if this will work, but in some of the old 2 cyl green waterpumps, you can press the impeller off and turn the shaft around and reassemble. John
Mark
07-11-2003 04:22:55
 Re: Re: M5 water pump shaft in reply to John Mc, 07-10-2003 09:39:44
John, Thanks for the idea, but this shaft is different on each end. I smoothed it up with very fine emery cloth and so far it isn't leaking. Time will tell, if it doesn't work I'll have a new shaft made.Thanks again. Mark
