Did mm ever build a cat?
Tom
03-02-1999 20:51:44
Talking to a friend of mine i mentioned that mm never built a cat like alot of other companies.He said i was wrong and that a man showed him a picture of a avery and in the background was a MM cat that looked like a R MM.But he grew up working for a MM dealer and this is the only one he had ever seen,so he wasnt sure if someone made it or not.
ME
04-13-1999 18:53:41
 Re: did mm ever build a cat? in reply to Tom, 03-02-1999 20:51:44
NO, BUT THEY BUILT A LOT OF "DOGS"
Brian Rukes, The M-M Registry
03-02-1999 21:55:05
Hi,
Okay, first off, I assume you are talking about a crawler-type tractor when you say a "cat". Only Caterpillar really built "Cats", but a lot of tractor companies built crawler tractors.
Yes, M-M did build crawlers. MoTrac crawlers and 2-Star crawlers are the most popular examples.
Hope this helps.
Respectfully,
Brian Rukes
The M-M Registry
robert cook,o.m cook co.
05-11-1999 12:27:42
 Re: Re: did mm ever build a cat? in reply to Brian Rukes, The M-M Registry, 03-02-1999 21:55:05
I have a mm crawler proto type for the motrac series. How many were built?
Does anyone have one for sale?
Harold H
03-08-1999 17:39:15
Brian,
I have never seen a M-M crawler and can't find any information on them. What years were they built?
Thanks,
Harold H
03-10-1999 10:23:13
 Re: Re: Re: did mm ever build a cat? in reply to Harold H, 03-08-1999 17:39:15
Harold,
M-M built its 2-Star crawler in 1958 (only 51 made).
Its MoTrac crawler was made in 1960 and 1961. Only 38 gasoline versions and 61 diesel versions of those were made.
With those low production numbers, it's not surprising that many people haven't seen one. I've only seen one in person myself, and it was in a parts yard.
Hope this helps.
Respectfully,
Brian Rukes
The M-M Registry
Ed Berry
09-02-2001 20:03:19
 Re: Re: Re: Re: did mm ever build a cat? in reply to Brian Rukes, The M-M Registry, 03-10-1999 10:23:13
Dad has a motrac crawler with a loader and the gas engine and yes he still uses it runs fine had no clue only 38 were made wonder if any one else has a working motrac just thought i would post this to let people know that one is alive and well in wisconsin
Jim D
06-14-2002 21:29:28
 Re: Re: Re: Re: Re: did mm ever build a cat? in reply to Ed Berry, 09-02-2001 20:03:19
I have a MM crawler that may be a 2star. Like to know how to tell it apart,from a motrc. Can not find searal#.
It has on the hood a drop about one inch with a sceen and a runded front. It also has a scoop. It runs but needs some work.
COOK
03-18-1999 18:20:10
IN BUCKLEY MI. AT THE BUCKLEY STEAM SHOW I SAW MM CRAWLER. THAT WAS IN AUGUST OF 98.
Harold H
03-11-1999 17:12:26
Thanks Bryan,
The small numbers explain why I had never seen one or even heard of one.
Harold H
Tom Peterson
04-10-1999 21:46:29
 Re: Re: Re: Re: Re: did mm ever build a cat? in reply to Harold H, 03-11-1999 17:12:26
I've seen one MM "cat" in Oregon and didn't believe they existed until I'd seen it.
