Minneapolis Moline Tractors Discussion Forum
G950 front stack weights
Adam
11-03-2003 22:44:02
Does enyone know if there were diferent styles of weights produced by MM? Would older weights like off a Z,U,or older tractor fit the front of a G950? I don't know as much about the older MM tractors. The reason I ask is because I know a man from OK. that has 15 or more MM front weights!! Thankyou for eny help you may have!
BMG
11-04-2003 15:38:28
 Re: G950 front stack weights in reply to Adam, 11-03-2003 22:44:02
Adam,
I believe MM never made front nose weights for the Z or U series. Only wheel weights. Someone will correct me if I'm wrong. The first nose weights came out with the 445. They're typically referred to as banana weights since that's what they looked like. MM started producing suitcase weights in the mid to late 60s. Your 950 would have had suitcase weights originally.
Brian
David
11-05-2003 06:54:38
 Re: Re: G950 front stack weights in reply to BMG, 11-04-2003 15:38:28
My uncle use to have a G900 that came with a full rack of banana weights, what a pain to put on and off compared to the suitcase weights!
