Minneapolis Moline Tractors Discussion Forum
MILITARY
BG
12-20-2003 16:31:11
I JUST GOT A TRACTOR THAT I'M NOT SURE WHAT IT IS. I THOUGHT IT WAS SAPOSED TO BE A U-MIL BUT IT HAS G SHEET METAL AND FRAME RAILS AND A 340 CI MOTOR. IT HAS THE BRASS TAGS ON THE FENDER AND IT SAYS 56 HP. IT ALSO HAS THE LIFTING BRAKETS. I HAVENT GOT THE TRACTOR HOME YET TO REALY LOOK IT OVER. IT ALSO HAS THE FOOT CLUTCH SHUTTLE SHIFT AND A LOADER AND DUEL WHEELS. I DIDN'T KNOW IF MM MADE SUCH A TRACTOR BUT I THOUGHT IT WOULD BE A HANDY LOADER TRACTOR SO I BOUGHT IT. WAS JUST WONDERING IS ANY ONE KNEW ANY THING ABOUT IT.
THANKS BG
BG
12-21-2003 19:01:17
 Re: MILITARY in reply to BG, 12-20-2003 16:31:11
THANKS GUYS I COULDNT FIND ANY INFO.
THANKS BG
BMG
12-21-2003 08:24:49
BG,
You've found yourself an extremely rare tractor. You've described a UMIL exactly. There were only 42 made in 1953 only. There was an operator's manual sold on eBay a couple weeks ago with the picture on the front. G grill and front end on a U chassis. I believe there was a picture in the MM Corresponder a couple months back of one of these tractors too. You'll need the serial # off the trans housing to know for sure. You should post a picture when you get it home so the rest of us can be educated on such a model.
Brian
Kelvin
12-20-2003 17:48:26
Yes, MM made a military tractor like that. I think it was the UTIM (military). It did have a larger engine than the agricultural U.
John G
12-20-2003 17:35:57
GTC??? They used the 340 cu on LP. Sounds unusual.
