1355 oil filter maintenance
D Ward
03-26-1999 21:31:12
My MM has had an acessory filter put on. It is a Baldwin canister to whick they ran a line (rubber, hydraulic?) from the left side case where the oil pressure gauge line feeds, under the chassie to the right side where the cannister is mounted.
1. Is there a oil port that could be used from the right side of the engine, eliminating the risk of catching the line on something and abruptly loosing oil pressure?
2. If not, could a line be run through the hole between the cab/fuel tank and the engine case, thereby protecting the line from snag?
3. Can one use a ridgid line instead of the hydraulic type hose?
Thanks for any comments.
