Minneapolis Moline Tractors Discussion Forum
MM RTI Clutch
Barry
01-07-2004 09:44:03
I was wondering if anyone knew what size clutch disc was in a MM RTI. I need to replace the disc, pressure plate, throw out bearing and the pilot bearing. I want to get the parts before I tear it down. I seen where there a four different clutch plate for the R. Any help would be appreciated.
Thnaks,
Barry
billy montgomery
01-11-2004 07:26:27
 Re: MM RTI Clutch in reply to Barry, 01-07-2004 09:44:03
My parts book shows a 9 inch for tractors up to no.420844 and no.0054800001 and after uses 10 inch clutch
barry
01-09-2004 08:35:09
The year of my RTI is 1949. It came with a Lull loader also. Where would anyone find all the clutch parts anyway?
Kelvin
01-08-2004 18:13:42
Early R's had a much smaller diameter clutch. (Same dia. as a MM V) I don't know when the change was made, but you need to know the year of your R.
Mopower
01-08-2004 09:49:40
I tore down an RTI and may have the clutch parts around yet so I will see what I can find and measure.
-Ethan
joe skinner
01-07-2004 16:14:48
barry, I replaced the clutches in two RTI's they were the same as WC allischalmers size wise but the hub in the center is different of course. I got linings and rivited to my old center. just ordered more of the linings today think I mite have a good center on hand to can check later, to see if I wrote down the other numbers for the parts you mentioned. joe
