Minneapolis Moline Tractors Discussion Forum
RACE OUT
BOB
02-04-2004 06:23:06
How do you get the race out on the bottom of the
front end (narrow)on a rtu 1947?
I'm trying to replace the top bearing and race,
but i can't get the top race out without removing
the bottom race. I'VE HEATED AROUND THE OUTSIDE TO NO RESULTS. THERE'S NO PLACE TO PUT A DRAFT PIN IN TO KNOCK OUT THE RACE. THANKS FOR YOUR HELP
BOB
Lon
02-04-2004 11:02:37
 Re: RACE OUT in reply to BOB, 02-04-2004 06:23:06
You can weld a bead of weld around the race when it cools it should shrank enough to fall out ? If that fails weld a slam hammer to it it should come out hope this is helpful!!
