Minneapolis Moline Tractors Discussion Forum
info needed on mm gbd
Barry
02-13-2004 13:50:15
hi. I am looking at a GBD but have a few questions. the tractor i am looking at has no fenders and wrong wheels fitted are these parts rediably avaible either as used or repro? i have heard that early tractors had smaller fenders is this true? did all tractors have hydralics or was this an option? what is the weight of the tractor.
hope there is someone out there who can help.
thanks in advance.
Taylor
02-21-2004 18:49:41
 Re: info needed on mm gbd in reply to Barry, 02-13-2004 13:50:15
I have a set of rims, and hubs with a spare rim that I removed from my gtb because I am going to pull it and put on pressed steel. I am located in Ky if you are interested.
BMG
02-15-2004 16:23:41
Barry,
Early GTBD models had clamshell fenders similar to a UB. Later GBD models had large wheatland fenders that wrapped over the wheel. I've found Moline used 2 different widths of these wheatland fenders. There's about 2-3 inches difference in width. These large fenders can be hard to find but occasionally you'll find a tractor puller who's removed these large fenders and is willing to part with them. The fenders or wheel centers are not being reproduced to my knowledge. You may be able to advertise the wheels on your GBD if they are pulling wheels. You may find someone willing to swap you original wheels and fenders for your wheels if they are custom pulling parts.
Brian
