Minneapolis Moline Tractors Discussion Forum
MM R Carb.
Alex
03-08-2004 17:02:26
Just picked up an R. Has no carb and Connecting tube (down riser) Will a carb and parts from a Z fit in place or do I have to use from R only. About how much are they?
Alex
03-09-2004 20:13:42
 Re: MM R Carb. in reply to Alex, 03-08-2004 17:02:26
Thank you! I will try to find them.
Kelvin
03-08-2004 17:22:01
If your R has the EE (165) cubic inch engine, I would reccommend that you search until you find the correct carb. Its a Marvel Schebler TSX 30,or 36 or (There's one other carb. number, I forgot.)
You also need the correct "down riser" from the manifold. Since the Z carb was larger, it used a shorter riser. You need the correct one for an R so the governor link will be the correct length.
