Minneapolis Moline Tractors Discussion Forum
Motor sucks in air through exhaust....???
Angus
04-05-2004 18:47:32
My 49' UTS sucks air back in through the exhaust pipe every few seconds while running. Could the timing be off or what else could it be? it runs good but i just noticed that today.
RJ
04-05-2004 21:14:15
 Re: Motor sucks in air through exhaust....??? in reply to Angus, 04-05-2004 18:47:32
Sounds like you may have a burnt exhaust valve, or an exhaust valve out of adjustment & not closing all the way or not seating properly. Check valve lash adjustments & then give it a compression check on all the cylinders.
Good luck
