HOW CAN I PUT PRESSED STEEL ON A U?? PLEASE HELP
Todd
04-18-1999 20:24:19
I want to put pressed steel rear wheels on a "U" and cant find any hubs that will work, can anyone tell me what I need? I think the axles are 3 inch diameter.
glenn
04-20-1999 18:48:57
 Re: HOW CAN I PUT PRESSED STEEL ON A U?? PLEASE HELP in reply to Todd, 04-18-1999 20:24:19
Oliver hubs will work,you will have to machine or grind the keyway a little.I had a UTS and changed the axles so I machined mine but a hand grinder will work.
mm
04-19-1999 14:45:25
Yes you can. The right G-1000 hub will do it or you can flange the axle.
