Minneapolis Moline Tractors Discussion Forum
MM 165 Power Unit
ACEd
04-12-2004 07:53:15
Just bought an old MM 165 power unit - s/n on motor starts with 45 but I don't remember the rest. Trying to find out more about it. Where is P/U S/N - I think it should start with 021? Also it is hand crank only and has a standard fuel tank, but it was run on LP with an Ensign Type R regulator and what looks like a big Ensign carb for such a small motor. (Looks like exactly what is on a U or G) Looks like a factory set up on rught front of motor except for conflict with conventional fuel tank and I thought the R & Z used a smaller regulator. Also it has RE226A heads - can't find info on these ever on an R or 165 - but found them on early low compression Z - any info on heads appreciated.
