Minneapolis Moline Tractors Discussion Forum
horsepower of minneapolis U
Andrew
07-10-2004 16:18:34
how much horse does a u minneapolis moline have
Kelvin
07-12-2004 20:05:46
 Re: horsepower of minneapolis U in reply to Andrew, 07-10-2004 16:18:34
Actually, Andy, Everybody so far is right.
If its stock, it depends on what year it was built, and what cylinder heads it has. The early KEF engine "Straight Block" had limited choices for upping the HP with higher compression cylinder heads.
Later "Split Block" engines could be modified with stock parts (heads, manifolds, pistons, blocks from later tractors to nearly or maybe even more than double the posted 45 hp.
DOK
07-11-2004 06:34:21
Used Tractor Guide indicates 45 HP.
Captainhookerus
07-10-2004 23:17:40
How strong do you want one? What are you going to do low gear pull, auger corn or what ever? Email me and I will send you some pictures of some strong one's. Ken
S.M.
07-11-2004 16:41:16
 Re: Re: horsepower of minneapolis U in reply to Captainhookerus, 07-10-2004 23:17:40
"Beware" of the Captain!!!
dale foland
07-11-2004 23:47:47
 Re: Re: Re: horsepower of minneapolis U in reply to S.M., 07-11-2004 16:41:16
who might that be
