Minneapolis Moline Tractors Discussion Forum
Jet Star 3 steering
BA
09-17-2004 18:40:24
On the road the steering wheel free wheels ,and the front wheels don't respond till I slow down .What should I check first? Thanks
Kelvin
09-23-2004 18:16:38
 Re: Jet Star 3 steering in reply to BA, 09-17-2004 18:40:24
I really don't know what could be causing your problem, but I would check the fluid level first. Then I would see if you had any steering with the engine off.
There is a valve (I think its the valve on the bellhousing) that is supposed to trap fluid in the steering circuit so the tractor can be steered if you lose power/hydraulics/etc.
Another thought-If your hydraulic filter is up under the seat, the pump could be sucking air through any of the fittings or the canister seal on the filter itself and cavitating at high rpm.
The only way to test this i can think of is with the throttle at road speed, does the 3-point work?
These are just thoughts. You might call Wendell Everett 740-922-3335, or Lenny Baucom 1-800-658-2309.
