MM Heads
EJ
05-26-1998 08:12:52
I have a pair of "GE 30 Z" heads on a 1953 UTS and
I would be interested in knowing the compression
ratio, combustion chamber volume etc. Thanks
larry h
05-26-1998 16:57:29
 Re: MM Heads in reply to EJ, 05-26-1998 08:12:52
there should be a number like 10A etc if you can give me this i can try and help you : I have a pair of "GE 30 Z" heads on a 1953 UTS and
: I would be interested in knowing the compression
: ratio, combustion chamber volume etc. Thanks
Joe Leising
05-26-1998 17:19:11
 Re: Re: MM Heads in reply to larry h , 05-26-1998 16:57:29
: there should be a number like 10A etc if you can give me this i can try and help you : : I have a pair of "GE 30 Z" heads on a 1953 UTS and
: : I would be interested in knowing the compression
: : ratio, combustion chamber volume etc. Thanks
Try going to jeremy fiorelli's homepage. He has a very complete list of heads for MM's including compression ratios, chamber volumes, etc. I'm not sure of the address, but it can be reached through the MM Registry Links Page at
www.angelfire.com/ok/mmreg/rukes2.html
Hope this helps.
Joe
Jeremy Fiorelli
05-30-1998 19:17:28
 Re: Re: Re: MM Heads in reply to Joe Leising, 05-26-1998 17:19:11
Here is the Address to my Cylinder Head Specifications page. The heads you are looking for are towards the bottom of the page under "COMPRESSION RATIO VERSUS ALTITUDE" hope this helps you if you have any questions please feel free to e-mail me.
Thanks,
Jeremy Fiorelli
fiorelli@cscu.csc.edu, or jfiorelli@hotmail.com
