Minneapolis Moline Tractors Discussion Forum
Are 38 rears too big??
Angus
11-16-2004 14:24:37
Is first gear on a UTS low enough to turn 16.9x38's?? Did they make a UTS with a slower 1st gear?
Andy2
11-16-2004 17:11:01
 Re: Are 38 rears too big?? in reply to Angus, 11-16-2004 14:24:37
UTS' have faster first gears than UTU's If you find a UTS with 38" wheels they are slower than ones with 30's; I think the bullgears are the difference.
Angus
11-16-2004 19:30:09
 Re: Are 38 rears too big?? in reply to Andy2, 11-16-2004 17:11:01
How can the UTS be slower with 38's if you say the utu has the slower gear?
Andy2
11-17-2004 19:04:11
 Re: Are 38 rears too big?? in reply to Angus, 11-16-2004 19:30:09
Most UTS' came with 30's and some 38's. 38's had a slower bull gear, because the 38's are taller than than the 30's and require less RPMs at the axle shaft to maintain the same speed as a 30. If you take a UTS that came with 16.9 X30 tires and put 16.9X38 wheels and centers and tires it will speed it up a lot more than If you if you put them on a UTS,(or UTU) that came with 13.6X38's. I had a UTU and first gear was slower with the same tires,(13.6X38) than my UTS. I suspect it was to go slow whe cultivating delicate crops.
