Minneapolis Moline Tractors Discussion Forum
hub torque
bassndeere
12-06-2004 18:27:13
What is the proper torque for the 2 nuts that attach the hub cap down to the hub. Don't want to crack the cap. Thank you
mowr
12-08-2004 19:25:33
 Re: hub torque in reply to bassndeere, 12-06-2004 18:27:13
Could you give us more to go on? Make and model, two or four-wheel drive, wheel hub or other, maybe even a picture. Thanks.
bassndeere
12-09-2004 17:27:20
 Re: hub torque in reply to mowr, 12-08-2004 19:25:33
Hello mowr,
Sorry about the lack of a good desription. 1948 RTU. The 2 nuts on the u-bolt that hold the hub on the rear axle. Thanks for the help.
Don
mowr
12-09-2004 20:16:14
 Re: hub torque in reply to bassndeere, 12-09-2004 17:27:20
Don, Thanks for the update. I honestly don't have that info. If you don't have an RTU book that shows it, perhaps you can find a list that shows general torque specs based on bolt diameter, hardness, and type of thread (fine or coarse). Sorry I can't be more helpful. Good luck.
Clyde
12-10-2004 06:23:46
 Re: hub torque in reply to mowr, 12-09-2004 20:16:14
Neither the maintenance manual or the shop service manual for the R specify a torque for these hubs. They do both mention having the nuts facing up and the key slot down when adjusting them. After tightening and operating the tractor for a few minutes, retighten. I checked a manual for a U, and it has not surprisingly the same exact wording in respect to this subject.
