Minneapolis Moline Tractors Discussion Forum
UB Oil Filter
JohnUBTexas
12-23-2004 06:57:01
I have ordered an Oil filter from NAPA that is suppose to fit and I have ordered the service manual for this tractor but until it comes I was hoping someone could answer a question. Is the Oil filter in the Pan on the 283c-4 UB Special? I can't seem to locate an access plate or cup anwhere. If in the pan where can I get new pan gaskets do I need to make them out of gasket material and PCV? Thanks to anyone who helps as you can tell I am new at this, my first restoration project 1955 UB Special LPg.
SWMolines
12-23-2004 08:35:58
 Re: UB Oil Filter in reply to JohnUBTexas, 12-23-2004 06:57:01
There should be a round cover on the RHS (if I recall correctly) of the oil pan that is removed to replace the oil filter. You do not need to remove the oil pan.
You can find the filter number on the Wix Filter website under off-road vehicles.
Good Luck!
todd08
12-23-2004 09:22:03
 Re: UB Oil Filter in reply to SWMolines, 12-23-2004 08:35:58
I would say your looking for a wix 51114.
johnUBTexas
12-23-2004 09:40:54
 Re: UB Oil Filter in reply to todd08, 12-23-2004 09:22:03
Uh oh I crossed to a Wix 51111 wonder what the difference is, thanks for the location info.
Tranny Question.
should I use 80w90 in the trans or hydrFluid/ATF I read the g1000 prefer 80w90.
Kelvin
12-24-2004 16:34:01
 Re: UB Oil Filter in reply to johnUBTexas, 12-23-2004 09:40:54
The 51111 fits the canister on the left side of older, gasoline U and UB (regular, not special).
Kevin Moschenrose
12-23-2004 11:36:42
The wix 51111 has stubs from the center of the filter one on each end where as the 51114 is flat on both ends.
johnUBTexas
12-24-2004 17:46:22
 Re: UB Oil Filter in reply to Kevin Moschenrose, 12-23-2004 11:36:42
Yes , I opend the box and those tabs were there, i tried to get a 51114 but WIX does not list such a number and Napa could only cross to a 51111, I cut the tabs off in the shop and bolted it up fine but I would like to get the right filter can you double check your number for me.
Kevin Moschenrose
12-24-2004 19:49:42
 Re: UB Oil Filter in reply to johnUBTexas, 12-24-2004 17:46:22
John, Yes my bad the number you need is WIX #51118. I am not sure though that it will come with a new cover gasket " flat o-ring" or not for the cover.I really just can't remember for sure. Sorry about the typo. I got an old logo MM filter some where in my collection of filters and I can possiablly get you the O.E.M.# from MM if you want.
JohnUBTexas
12-28-2004 07:42:35
 Re: UB Oil Filter in reply to Kevin Moschenrose, 12-24-2004 19:49:42
Thanks, All is well in the filter department now,Wonder why they don't cross the UB Special to this filter.
Kevin Moschenrose
12-28-2004 09:23:29
 Re: UB Oil Filter in reply to JohnUBTexas, 12-28-2004 07:42:35
Well John, That's is a good question. I don't know why either. I can only guess that they don't know there is some difference between a UB and a UB special, this the only thing I can think of at this time.
