1355 External Control Detent Valves
D Ward
06-28-1999 16:18:24
I have installed a front loader. When I move the control lever on one of the external hydrolic circuits, the cylinders move only an inch or two the first time then not at all. The return flow adjusting screw is backed out all the way, no more adjustment left. The other circuit works ok (both with the other cylinders on the loader and if I switch the circuit sides.
I assume this means that I need to rebuild the control valves?
I tried to adjust the Manifold control valve to no avail. Any suggestions or comments would be appreciated.
