MM-UB wide front end
Joe Gleason
07-06-1999 18:29:32
I bought a MM UB with a wide front end. The main iron across the front was a flat piece and not angular shaped. Was a wide front end ever an option on a UB or was this something someone put on it from another model? I was also wondering what other models I could use a narrow front end off of to convert it back?
bret green
07-06-1999 22:07:42
 Re: MM-UB wide front end in reply to Joe Gleason, 07-06-1999 18:29:32
The UB's had 3 different front ends the
adjustable wide front,a single front wheel,
and the one most had the two wheel narrow.
If you post or e-mail the sn# of the tractor
I can tell you what front end it had when built.
The front end off a row crop U will fit.
Thanks
Bret
