Minneapolis Moline Tractors Discussion Forum
Hood on G706 too short
5star2
01-14-2005 16:20:53
bought a G706, sheet metal laying off to the side, when I put the hood on it is 1 inch to short it measured 85 3/4 inchs Could this hood be from a GVI??? or ????
BMG
01-17-2005 11:59:37
 Re: Hood on G706 too short in reply to 5star2, 01-14-2005 16:20:53
I had to shim the lower radiator mounts on my G707 to get the hood to align with the radiator and dash assembly. Loosening the dash mounts helped but I was not able to get all the adjustment I needed. The radiator was bolted on with 4 bolts to the framework. I added shims to the lower mounting bolts to tip the radiator rearward. Throw in the LP tank sticking through the hood and it made it that much more difficult to get the hood to align properly.
Brian
Joe Skinner
01-16-2005 12:32:30
Just a thought but how well is the rad support is it straight or could it be tilted out of position some?
ejr
01-15-2005 11:29:49
I used a 705 hood on my GVI.
Roger in Ks
01-15-2005 08:07:52
Does this tractor have an aftermarket cab with air? The front may have been removed and a 1 inch block put in place to make room for the air conditioner pulley.
5star2
01-15-2005 11:13:42
 Re: Hood on G706 too short in reply to Roger in Ks, 01-15-2005 08:07:52
No cab and the front is bolted tight like it sould be ??? Ed
