335 MM Utility
Monte Berend
07-20-1999 11:11:14
I'm looking for the outside tie rod ends of a wide front. Can find the inside ones. May have to cut and weld.
It locks up in low range and I need to shift to high range and then to low then it works. The PTO keeps running when I take it out. Are these 2 things expensive to fix?
Mike
07-20-1999 21:05:08
 Re: 335 MM Utility in reply to Monte Berend, 07-20-1999 11:11:14
I can't help you with your tie rod ends, but your problem with the PTO running while disengaged really isn't a problem, they all do that. (I'm making this statement assuming that it doesn't turn with something hooked up to it while it is disengaged.) As far as your shifting problem while in low range, it is something that is quite common. I have the same problem with my 4-Star. Just get in the habit of throwing it into high range before shifting, and you won't have a problem. I guess what I'm trying to say is that the problems that you are having aren't really problems at all, but are characteristic of not only the 335, but of several MM models of this design. Good Luck,
MIke
