MM U cylinder heads
Dan O'Brien
07-20-1999 16:02:30
I have a 49 MM UTIL on which the front cylinder head is cracked (GE30E). I would like to know what heads will work on this tractor (compression ratio etc.). I would be interested in purchasing heads if any one has any in the Colorado area.
glenn
07-23-1999 03:55:00
 Re: MM U cylinder heads in reply to Dan O'Brien, 07-20-1999 16:02:30
I have two of these heads, ready to bolt on, no work needed,for sale. Can ship UPS, I live in MD. Glenn
Mike
07-20-1999 20:45:10
The GE30E has a compression ration of 5.4 to 1 when used on a 4-1/4" bore U, and an over all height of 5"
The following heads should work.
10A4205 (5.2 to 1) Height of head 5
10A4209 (5.5 to 1) Height of head 5
10A4210 (6.95 to 1) Height of head 4-17/32
GE30Z (6.34 to 1) Height of head 4-17/32 GE30J (6.85 to 1) Height of head 4-17/32 When using the shorter heads, (4-17/32) you may have to use 1/2" spacers under the nuts for the head bolts, and 1/2" spacer blocks under the water manifold ports, because the studs in the block will be too long.
How badly is your head cracked? It may be cheaper to get your head fixed. The other solution is to try and find another GE30E head.
Good luck,
Mike
