Minneapolis Moline Tractors Discussion Forum
Need info on 2 row self propelled combine
7810
03-29-2005 18:12:39
Anyone have info on a LC(?) 2 row self propelled combine? Anyone interested in one?
The serial number is 38904246 and has a 206-4 engine.
Thanks.
John Grandfield
03-29-2005 20:09:15
 Re: Need info on 2 row self propelled combine in reply to 7810, 03-29-2005 18:12:39
LC is the UNI Huskor, probably sitting on a Uni Tractor, where are you located? That huskor is a corn picker that removes the husks, hopefully, not a combine. I've got such an animal here, what info are you looking for? The other tag will give you the model and year of the tractor. If the tractorhas a V-4, it'll be a model L, could have a V-4 flathead, or a V-4 overhead valve.
Kelvin
03-29-2005 18:52:24
2-row? Are you sure its not a LD picker-sheller?
And is the engine a V-4? If it is a V-4 there should be another tag on the frame by the rear wheel steering gear.
