Minneapolis Moline Tractors Discussion Forum
M-M Jetstar 3 no low range
b peppler
03-30-2005 11:33:53
I would like to buy a 1964 jetstar 3 when i put it in low 1st gear it will move when I have it in 2,3,4,5 gear it will not go. If I put it to high 1,2,3,4,5 they all go well. if I start it in high range 3rd gear and pull the torque to low it will go for about 50 yards and stop moving. Is there an ajustment to fix this or will I need $$$$ to fix it.
b peppler
03-30-2005 14:23:00
 Re: M-M Jetstar 3 no low range in reply to b peppler, 03-30-2005 11:33:53
Do you have any idea what the parts would cost to repair the torque??
F M-M
04-02-2005 19:03:19
 Re: M-M Jetstar 3 no low range in reply to b peppler, 03-30-2005 14:23:00
I just fixed my M-5 that did the exact same thing. No low. In that tractor they used little sprag rollers and springs to work as an over running clutch for the low. Yours is probably similar. It cost me about $200 for what I needed. You will have to split the tractor at the bell housing to get it out. You can get the parts form Welters 417-498-6496 or send it to them and they can put it together for you. It isn't too hard to do if you have a manual.
havvey
03-30-2005 13:58:08
rebuild the torque amp
