Minneapolis Moline Tractors Discussion Forum
1951 RTU water pouring out carb
1951 RTU
04-18-2005 03:43:19
Purchased a 6 volt charger and charged what we thought was a weak battery. The next day it still was a little slow to turn over and then siezed like(a few seconds later water/antifreeze poured out of the carburetor. I pulled the plugs to see which if any were wet. Water poured out of the second plug from the front of the tractor.
I sure hope this is a head gasket and not a cracked block or something. Any ideas would be greatly appreciated.
Kelvin
04-18-2005 18:41:47
 Re: 1951 RTU water pouring out carb in reply to 1951 RTU, 04-18-2005 03:43:19
That sounds serious. Can't help much from here, but it looks like you'll have to take the head off and look inside. Its not a terrible job on an R.
Be sure to carefully inspect the top of the combustion chamber above the piston. I have found 1 block that was cracked around the very top of the cylinder bore and the top pushed upward a bit.
