Minneapolis Moline Tractors Discussion Forum
Starter removal
1951 RTU
04-25-2005 18:33:16
How do I take the starter of a 1951 RTU? I only see the bolt with what looks like a set nut on the side of the starter. The starter hums/whines and the solenoid clicks when I try to turn her over.. It was working and then quit. Brand new battery with full charge. Thanks.
Kelvin
04-25-2005 19:16:10
 Re: Starter removal in reply to 1951 RTU, 04-25-2005 18:33:16
If you didn't clean all the connections, especially the ground where it bolts to the tractor, try that first.
that setscrew does hold the starter in place. However, if its like the earlier Rs, and has the EE engine, you can take those 2 long bell housing bolts out and remove the starter with the mounting adapter. If yours is made like this it might be easier, the starter sometimes rusts tight in the adapter.
