Minneapolis Moline Tractors Discussion Forum
R carb
1951 RTU
05-01-2005 09:01:24
1951 RTU had been sitting for 3 years so I cleaned the rust out of the bottom of the carb. What else should I look for/at? Will I be able to find a carb kit or a new carb for it? Thanks.
old
05-01-2005 10:05:19
 Re: R carb in reply to 1951 RTU, 05-01-2005 09:01:24
Another thing I would do before you try to start it up I'd put a few onces of tranny fluid in each cylinder to make sure its loose and also to lube the rings and valves since they will be dry.
old
05-01-2005 10:03:25
You should be able to find a kit and or a carb, a new/rebuilt carb will run you around $250-300. As far as the settings the slow spped will be about 3/4 to start with and the main jet screw will be about 1-1/2 to start with. The old R was a pretty good little tractor with a lot of guts for its size, I've had 2 of them in the past and they where fun to play with. The hand clutch does take a little to get usto if you haven't used them before.
What?
05-01-2005 17:15:31
 Re: R carb in reply to old, 05-01-2005 10:03:25
Motec can rebuild your carb for $75.
old
05-01-2005 20:27:37
 Re: R carb in reply to What?, 05-01-2005 17:15:31
As I said a rebuilt carb I.E. not the carb you have but one that has been rebuilt as in almost new is $250-300. Thats not haveing some one rebuild the one you have.
grandfield
05-01-2005 19:11:36
Motec does a fine job, including testing on an engine before returning it to you. It's a COMPLETE rebuild, not just clean and a kit. Highly recomended! John
1951 RTU
05-01-2005 09:04:58
What is the starting point for this carb? How many turn for both high and low speed. Thanks.
