Minneapolis Moline Tractors Discussion Forum
antifreeze in Cylinder #2
1951 RTU
05-15-2005 07:27:04
Could a faulty freeze plug cause antifreeze to leak in to a cylinder? Is it likely the freeze plug froze and broke or maybe rusted causing a leak. Thanks in advance.
Curt
old
05-15-2005 08:01:52
 Re: antifreeze in Cylinder #2 in reply to 1951 RTU, 05-15-2005 07:27:04
Not a freeze plug, could be haed gasket, sleeve seal or a cracked block. Freeze plugs are on the out side of a block and are made to pop out before a block cracks but most of the time they don't work.
Billpa
05-15-2005 17:06:56
 Re: antifreeze in Cylinder #2 in reply to old, 05-15-2005 08:01:52
everybody calls them freeze plugs but i think they are realy core plugs from casting the item.
1951 RTU
05-15-2005 12:48:51
The antifreeze is coming from above the piston.....
old
05-15-2005 13:13:54
 Re: antifreeze in Cylinder #2 in reply to 1951 RTU , 05-15-2005 12:48:51
Sounds like a cracked block, if I remember right an R has a water manifold doesn't it?
1951 RTU
05-16-2005 05:36:30
 Re: antifreeze in Cylinder #2 in reply to old, 05-15-2005 13:13:54
Has water inlet on left side. water outlet on the right side(head side).
