Minneapolis Moline Tractors Discussion Forum
stubborn block on R
1951 RTU
05-16-2005 05:52:46
I have removed the following. Head, exhaust manifold, intake manifold, water inlet, rocker arms, 3 nuts on right side of front block, 2 nuts on the left side that held the rocker arms. Can I take just the front block off? Am I forgetting something? She doesn't want to budge. The front block is cracked letting antifreeze in cylinder #2. Any tricks on removing a stubborn block? Thanks in advance.
Curt
1951 RTU
05-17-2005 05:31:19
 Re: stubborn block on R in reply to 1951 RTU, 05-16-2005 05:52:46
Kelvin,
Is the oil tube the tube going in the front left lower side of the front block? I did remove it. I didn"t remove the end caps. The engine isn"t stuck. Should I remove the end caps on #1 and #2? Do you have any other thoughts or ideas?
Curt
Kelvin
05-16-2005 19:04:01
Did you remove the oil tube from that block to the front of the crankcase? If so,
I'm pretty sure its just stuck on those studs.
Kelvin
05-16-2005 19:08:05
 Re: stubborn block on R in reply to Kelvin, 05-16-2005 19:04:01
Another thought: Did you remove the caps from #1 and #2 rods? I'm wondering if the rings are binding in the cylinder or stuck. Perhaps crank it over and see if the pistons will push it off the studs.
Curt Cooke
05-16-2005 06:27:39
I recall something unusual about those jugs like a couple of bolts that hold it to the crankcase from the underside. Seems that they are on the cam side and go up to the jug from underneath. Give it a look before the prying begins.
Kevin Moschenrose
05-16-2005 07:31:16
 Re: stubborn block on R in reply to Curt Cooke, 05-16-2005 06:27:39
Curt, you are correct on the bolts! There are three under there per block.
Heath
05-16-2005 09:02:43
 Re: stubborn block on R in reply to Kevin Moschenrose, 05-16-2005 07:31:16
I've never seen bolts on the under side of an R or Z block, unless they did on the late ones. To my knowledge, the only engines with the bolts undeneath on the camshaft side were the overhead valve 165's and 206's as used in 335, 445, 4 Star, etc.
Kevin Moschenrose
05-16-2005 22:23:21
 Re: stubborn block on R in reply to Heath, 05-16-2005 09:02:43
Heath, You are right! I looked at my junk R and then at my Big Mo 400 miltary 206/220 and they are on the 206 and not on the R. Too many torn down that I got them crossed. MY BAD!
