Minneapolis Moline Tractors Discussion Forum
MM UTU weight?
43casesc
05-19-2005 19:52:09
hey,
just bought a LPG MM UTU tractor with hydraulics, PTO, and a few other little goodies. i was wondering if anyone knew what this thing weighed from the factory, just for me to have a ballpark idea. also, does anyone know the horsepower on the UTU on LPG? another thing is the freeze plug on the back of the cylinder head is starting to rot out, and leak a little. does anyone know if there is enough room in the water jacket of the head for me to install a rubber replacment freezeplug there until i get the head pulled to install a new brass freeze plug? it also has a knock in the bottom end that the last owner said has been there for a long time. it sounds like a piston skirt slapping. are the UTU tractors with the KEF series (i believe) engines known for skirt knocks? we figure if it was a bearing or a cracked crank this thing would have quit running a long time ago. i appreciate it, and it is a neat ol'tractor. i intend to keep it and fix it up.
thanks for any info that anyone has, 43casesc in TX
Unimog
05-20-2005 19:32:40
 Re: MM UTU weight? in reply to 43casesc, 05-19-2005 19:52:09
Weight would be in the 5800-6000 range and power would be 46 PTO hp.
